HP Printers Photosmart 475 & A626 Printers
- Re: HP Printers Photosmart 475 & A626 Printers
03-08-2013 3:56 PM
Hi folks!
I have used the 475 for some considerable time and suffered the occasional paper jam, this seems to have been a bit endemic for this model. Finally, the last time, a small corner of the paper remained in the rollers and there it stayed. HP wanted £150 to have it overhauled in their UK Service centre, which is nearly 3 times its new cost,so I splashed out on a new A626, which is a similar machine with touch screen and apparently no paper jams. Now this reports a carriage jam but no paper has jammed. There appears to be now way of getting inside either beast, short of a big hammer, to find out what is amiss! I would dearly like to find out the way forward to get either one or both back into service. I hope that it does not mean yet another purchase as the cheap way. If HP Service Centre can do it, albeit at great cost, so should I if I knew how. Any Ideas?
2 REPLIES 2
03-08-2013 5:10 PM
Perhaps HP would just scrap your old printer and give you a new / used printer for £150.
Try to find out what rotates the rollers of a 475.
It may just be a tiny fragment blocking a sensor.
Similarly with the A626, it may be a sensor problem.
Have you tried using a hoover on maximum suck?
03-08-2013 7:07 PM
