HP Printer paperfeed problem
penneck
Anybody had a problem with an HP printer claiming it is out of paper, even though there is a stack of sheets in it? In this case, the printer is a Photosmart 7520. I cannot see any bits of paper which may be preventing the correct operation. As far as I can see, the thing that presses against the paper is complete, and moves correctly, though the switch I suspect it operates may not be working correctly.
Did you manage to fix it? If so, what was the solution?
Thanks for your help
1 REPLY 1
shutter
Fixes: 64
Re: HP Printer paperfeed problem
My canon mg 6851 does the same to me from time to time....I just pull out the paper holding cassette and bang it back in again ! ..
There is a site you may be interested in called  fixmyprinter.com... google it... and you may find some help there. if the above doesn`t work ! !
