HG612 - still ok?
throwawayforum
HG612 - still ok?
I've been using a HG612 for about five years and recently switched to plusnet. I see a lot of rather convoluted talk online about various types of modem being better depending on what kit is in the local Cab (LCBUS)?
Is this true or is it simply just a waste of money to replace?
12 REPLIES 12
Fixes: 418
Re: HG612 - still ok?
This Huawei modem works fine with Plusnet. They can also be unlocked so that you can get detailed performance statistics. If you have a decent router then stick with this combo.
I understand that whilst they may work better than an ECI one if you are connected to a Huawei fibre cabinet., they work just as well as an ECI modem if you’re connected to an ECI cabinet.
pjmarsh
Fixes: 20
LCBUS, is that your exchange code?  If so, I'm in Burscough as well!
throwawayforum
The Burscough gang checking in!
Fixes: 418
If you want to know which make of fibre cabinet you are connected to first identity the cabinet, see https://kitz.co.uk/adsl/cabinet-lookup.htm, then look at it and compare with this. https://kitz.co.uk/adsl/fttc-cabinets.htm
Mustrum
Fixes: 77
Did you not get a router when you switched? The Hub 1 does need an Openreach modem, and normally only cost the price of postage, and can be very handy if you have line problems.
throwawayforum
I did recieve a router but I did not even open the box - I never use the ISP provided stuff
VileReynard
Fixes: 20
Only for a small speed difference - not worth the cost of a new modem/router unless you have additional reasons such as:-
Gigabit cabling or superior wifi.
The Plusnet hub 1 is very locked-down and lacks many capabilities, although the wifi seems moderately good and its very cheap.
vultura
An interesting thread, thank you OP for asking this question and to those who have replied.
Has anyone seen my signature, it's gone missing.
Fixes: 418
@vultura
As you found this interesting it's worth correcting this post. https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/HG612-still-ok/m-p/1591511#M84363. The Plusnet Hub One does not require a modem as there's one uilt in.  However the Hub Zero does need one.
vultura
@Baldrick1 wrote:
As you found this interesting it's worth correcting this post. https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/HG612-still-ok/m-p/1591511#M84363. The Plusnet Hub One does not require a modem as there's one built in.
@Baldrick1 Looks like you have me confused with Mustrum.
Fixes: 418
No, I'm not confused. As you said:
It occurred to me that you might like to know that there is an error in one of the replies so that you were not left with wrong information..
vultura
Ahh, fair enough, it read like you wanted me to edit the earlier post and that post wasn't by me.
I did spot the typo, but as I don't have a Hub One or Zero I ignored it.
