HD widescreen webcam
chuffchuff
Any recommendations for a full HD 1080p video widescreen webcam calling on Skype, please?
Budget up to £100. I would prefer to use a separate mike.
Thanks.
6 REPLIES 6
DaveyH
Champion
Fixes: 12
Re: HD widescreen webcam
Logitech C9x0 range of webcams are excellent.
Strat
Fixes: 565
+1 on Logitech.
chuffchuff
Quote from: DaveyH
Thank you.
chuffchuff
Quote from: chuffchuff
Thanks.
I purchased a HD webcam & installed it, tested it on Skype using the sound playback.
I recorded some video to the pc, then used the Skype to complete the setup. Everything fine!
I had a call in to me on Skype this morning - great sound, clear as a bell,
no video.
I have not got Fibre Optic.
Does one have to have Fibre Optic to use a HD cam on Skype/internet?
MJN
Fixes: 5
Did you click the video icon?
There is no requirement to have a fibre connection for video, however the quality of video (and therefore whether it'll go all the way up to HD) is determined by various factors such as bandwidth, latency, CPU etc for both callers. Skype will determine what's possible though so you should only need to make sure it's enabled.
chuffchuff
Thank you for the suggestion.
The culprit - a faulty webcam - now replaced by the vendor & now we are up and running.
dick:quote
