HD failing???
- Re: HD failing???
HD failing???
15-03-2009 10:15 PM
Tonight the wifes laptop gave an odd error, I have never seen before along the lines of 'cannot load current user profile due to a network issue or corrupt user profile' it suggested logging on with a temp profile, but I declined. i logged on with the system admin account, and system restored to 2 days ago, and all fine. Event viewer shows alot of red errors about \device\harddisk\d has a bad sector. I presumed this suggested the HDD was dying, but on running chkdsk, and seagate seatools, nothing appears to be wrong. Is the HDD failing??? I have transferred all data over the network to another system just in case, but would welcome any advice.
5 REPLIES 5
Re: HD failing???
15-03-2009 11:20 PM
Go to the website of the HDD manufacturer - most of them have diagnostic software for download.
Failing that, I'm told that Seagate's diagnostics will work on most HDDs: http://www.seagate.com/www/en-us/support/troubleshooting_assistance
HTH
HTH
Re: HD failing???
15-03-2009 11:31 PM
Were is the laptop used as the error is normally for a Domain were the profile is downloaded from the server at logon. It certainly suggests its getting a profile from somewhere other than the local pc.
It doesn't suggest they drive is failing but backing up data is always a good idea
Re: HD failing???
16-03-2009 4:12 PM
Hi Samuria
Its certainly not used in a Domain environment, just on my own home network workgroup. I dont have Home Server or any other form of that sort of thing, as only have 1 desktop, and 2 lappies, so it would be overkill. After the system restore things seem fine, just worried that HHD was about to fall over. I will keep an eye on the error logs, and see what happens.
Chris
Chris
Re: HD failing???
16-03-2009 10:51 PM
Has the laptop been used at work or somewhere else which would account for trying to get the profile from somewhere else?
Re: HD failing???
17-03-2009 9:08 PM
No, its never been near a domain environment. Seems a bit odd, but it seems to be OK now. Chalk up to oddness
