Graphing scripts for an unlocked HG612.
avatastic
Since I'm the caring, sharing sort, if you want to generate a page like mine the scripts I modified can be found at:
get-statsd.pl
make_graphs.sh
LICENSE.txt
get_statsd.pl runs in the background, I start it with "screen -dmS get-statsd ~/linemon/get-statsd.pl"
make_graphs.sh runs as often as you like from cron.
I run the scripts on a FreeBSD environment so Linux, OS X, Solaris users will need to adjust the paths as appropriate.
[edit]Edited get-statsd.pl to better detect the line uptime, the regex in use was causing a nice sawtooth effect whenever the string was missing the minutes counter.[/edit]
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
