Since I'm the caring, sharing sort, if you want to generate a page like
mine the scripts I modified can be found at:
get-statsd.plmake_graphs.shLICENSE.txtget_statsd.pl runs in the background, I start it with "screen -dmS get-statsd ~/linemon/get-statsd.pl"
make_graphs.sh runs as often as you like from cron.
I run the scripts on a FreeBSD environment so Linux, OS X, Solaris users will need to adjust the paths as appropriate.
[edit]Edited get-statsd.pl to better detect the line uptime, the regex in use was causing a nice sawtooth effect whenever the string was missing the minutes counter.[/edit]
F9 member since 4 Sep 1999 F9 ADSL customer since 27 Aug 2004 DLM manages your line the same way DRM manages your rights. Look at all the pretty graphs! (now with uptime logging!) | |
