Graphics/drawing tablet usb or wireless
- Re: Graphics/drawing tablet usb or wireless
13-03-2021 10:05 AM
Looking for information about these items... Something I think I may be able to use, but not on a regular basis.. so it does not need to be "top notch" spec.... Initially looking for something that I can "get the feel of" using... but. would probably be worth getting something a bit better than the cheapest of the cheap end of the market. something that has a reasonable amount of quality but of reasonable cost..
Any advice on what to look out for, or suggestions to look at, to compare the specs/size/price/versatility etc would be useful.
out
13-03-2021 11:40 AM
I've got one of these, so if it's of any use it'll be in the post on Monday.
13-03-2021 12:54 PM
WOW ! Thank you.. I promise not to mess with it ! .. even though it doesn`t say it works with Linux.. . I expect it will, through WINE. and if not.. I`ll send it back ! . Let me know the postage, and a cheque will be in the post to you. ( nearest smiley to a post man ! )
13-03-2021 1:46 PM - edited 13-03-2021 1:46 PM
I'll send it to you on Monday @shutter
13-03-2021 2:06 PM
@Mook Thank You.
