Graphics card
- Graphics card
Graphics card
20-05-2016 1:53 PM
I've just been given a graphics cards , model 1GB Dedicated Nvidia Quadro K600 Graphics with HDMI displayport and DIV-I port on it.
I'd like to install it in a windows 10 desktop to support dual monitors, but cannot find any reference to it
Any advice would be appreciated (the applications used are Office email and chrome).
Re: Graphics card
20-05-2016 2:01 PM
You can usually connect 2 different monitors to the 2 outputs, or if the dvi port is dual you can get a splitter to supply 2 dvi monitors.
If you have only vga connectors on the monitors then you need to look at dvi-vga & display port-vga adapters. Unless you have the vga connector cable.
I use an hdmi-vga and vga outputs to supply my 2 monitors. Once you have the hardware connected then it should be picked up automatically.
Re: Graphics card
20-05-2016 2:20 PM
@HB thanks, monitors have dvi, hdmi and VGA (3 ports).
So it should work and find the monitors automatically?
Re: Graphics card
20-05-2016 2:43 PM
The card has a dual dvi connector and can support 2 monitors on the dvi.
Re: Graphics card
20-05-2016 4:30 PM
@journeys data Sheet here http://www.nvidia.co.uk/content/PDF/data-sheet/nv-ds-quadro-k600-us.pdf
Re: Graphics card
20-05-2016 5:04 PM
Not sure what is built in to W10 to assist managing desktop backgrounds as I only have W10 on my laptop but on my PC I use Multiwall which is excellent at allowing you to have the same picture across two or more monitors.
Forum Moderator and Customer
Re: Graphics card
20-05-2016 5:18 PM
Same as I have on my Linux setup. (only using different apps ;-))
Re: Graphics card
20-05-2016 10:55 PM
And the card is designed for CAD and 3D work, not 2D desktop and 3D gaming.
Still:
"Chipset: NVIDIA Quadro K600
Bus: PCI-Express 2.0 x16
Video Memory: 1GB DDR3
Memory Bandwidth:?29.0 GB/s
Memory Interface: 128-bit
Connectors: DVI-I, Display Port"
As a freebie, not bad. The nvida website has drivers for it, last updated driver is 2014.
