Graphics card or PSU?
- Graphics card or PSU?
Re: Graphics card or PSU?
06-03-2016 1:08 PM
to help you find the right psu and yes you would probably want a higher wattage unit, indeed the psu finder tool recommends a 600w or higher rating
however things like this are also usefull
https://www.avforums.com/threads/needing-a-psu.1453855/
wherein you find that your 750w alpine unit is in fact barely able to push out 400w
the CiT psu I linked before might not be the best, but unlike the alpine it is far less likely to take out all the other parts of the pc when it fails....
it might well be that the replacement required will need to be a decent 600w or 650w one and likely double the cost of the alpine you linked to, (cheapest google shopping links for 600w and 650w psu's
06-03-2016 2:58 PM
06-03-2016 11:35 PM
07-03-2016 2:13 AM
Eventually I decided it was better to spend a fair bit more on a quality PSU for the same reasons as PitchBlack.
Have had a 750W PSU for quite a few years but have a fair few internal HDDs.
Forum Moderator and Customer
07-03-2016 10:03 AM
The fact this gc takes 2 slots is a pita on this mb I did have a 6Gb sata controller in the pci-e slot but it is not covered, so back to the mb sata.
Hopefully this will last me for a few more years as I don't see me being able to upgrade anything for several years to come. (It has 38A on the 12V line as well).
07-03-2016 10:24 AM
The PSU is the heart of your PC and should never be skimped on ! as it could end up costing you a new Motherboard or GFX card .
HairyBiker has bought a decent GFX card and would be sad if his PSU Blew and ended up over volting his MB & new card which does happen !
07-03-2016 11:06 AM
07-03-2016 11:15 AM
of course as with all such things it couldn't of happened at a worse time, still the repalcements only took 2 months to scavange together, I didn't make the same mistake again with regards to the cheap /free supplied psu's and have always bought a reliable one since (currently I have corsair units in the desktops, partly because they have a 5 year rma period and partly because they provide a guarantee that if it fails and kills anything they will replace it as well as the PSU within that period)
however I've seen several cases of psu's going down and taking out everything in the case .... always its cheaper /free supplied with case type psu's, some people are just lucky enough for it not to happen to them though /
07-03-2016 12:09 PM
07-03-2016 12:21 PM
Quote from: Hairy Personally in over 30 years of using PC's I have NEVER had a psu blow on me.
I have had two cheap PSUs blow on me. The first time it took out the MB and GPU.
The second time it tripped the main fuse but no damage to any PC components.
You'd have thought I would have learnt my lesson after the first time
07-03-2016 2:30 PM
I've also had a kettle lead melt on me.
The plug (with 13A fuse) just gave off acrid smoke and melted.
I tried a second lead but nothing happened - so I used it as an excuse to buy a whole new base unit.
You cannot trust anything.
09-03-2016 12:40 PM
Installed new psu. Carefully routed all the cables. Powered up in to M$, went to run Thief. Got starting screen fine, but on play just crashed.
AC syndicate, reboots pc.
So waste of £25, can't return it as it is working and I have unboxed it. Will have to wait to next month to get a more powerful psu.
09-03-2016 1:28 PM
09-03-2016 2:08 PM
Not tried with anything else, or any other settings.
09-03-2016 2:12 PM
56A vs the 36 on the current one. Hopefully it is OK. Reviews are all good, one powering a gtx970 & i3
