Graphics card or PSU?
- Graphics card or PSU?
05-03-2016 2:17 PM
I am debating if it is the psu that isn't powerful enough (it is a 500W I got with the PC) or whether the gc is at fault.
PC is an Athlon FX850 with 8Gb, 2 Hdd & 2 ssd's. (only one of each active in my dual boot)
Any ideas on how to test further?
Re: Graphics card or PSU?
05-03-2016 2:23 PM
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-760/specifications
05-03-2016 2:31 PM
Bummer. Will have to wait for a new psu now.
05-03-2016 2:39 PM
Quote from: Hairy (it is a 500W I got with the PC)
Is that a 500W Peak or 500W Constant? If the former, yes, PSU needs to be evicted for one that can supply 500W Constant...
It's another example of fudging figures to make things look better than they are, a 500W Peak supply is usually only good for about 200-300 Watts constant, which is a bit of a con...
05-03-2016 3:08 PM
05-03-2016 3:48 PM
But what does make a difference is buy a decent make , and if our GFX requires extra PCIE 6pin power plug get one with a dedicated plug , not one with a molex connector
https://www.scan.co.uk/products/550w-corsair-vs-series-vs550-85-eff-80plus-white-230v-eu-certified-1...; something like this
05-03-2016 4:23 PM
05-03-2016 5:17 PM
Quote from: Hairy Why do they still add floppy connectors?
Because some front-panel accessories still use them, of course...
05-03-2016 9:45 PM
Quote from: Hairy The one I ordered has a 6 pin connector. (Along with 4 sata, 3 molex, 1 floppy ! Why do they still add floppy connectors? I haven't had a floppy disk drive in a PC for over 10 years now. I do have a usb one somewhere for when I need to use a fdd but last time was over 4 years ago.
multi card readers and fan controllers will use the floppy power supply (depending on the make) as can some other customisation things like case lights
as to the PSU if it isn't rated 80+ bronze gold silver or platinum its not worth the price, however don't get anything listed as 80+white or just saying 80+ certified as they tend to be on an equal par with unrated £10 in the O.E.M brown box from years gone by before it embraced a new direction as P.C. RipYouOffShop....
as to the cause of the crash, if your getting a frame freeze to black screen and stuck or blackscreen rebooting then its the power supply (and should be triggering improper shutdown warnings in the log on reboot)
if your getting bsod's then the error message should give you the problem when you google the event ID
06-03-2016 8:28 AM
06-03-2016 11:57 AM
I ordered an Alpine 750W one from ebay.
Not the cheapest or the dearest but was looking at the 12V line more than anything else as that is what powers the gc.
I can't really afford a "decent" psu, my budget is stretched buying this one. Didn't plan on buying anything else this month.
The crash is down to a semi-power off state, no video audio a buzz.
06-03-2016 12:15 PM
the psu you linked to only has a 4 min cpu plug, you can use it with a 4 >8 adaptor but I wouldn't advise it, much better ot buy something that is meant to be used for a newer system.
in which case this would be a much better choice http://www.cclonline.com/product/162162/CIT-ATV-500W/Power-Supplies/CiT-500W-Active-85-80-Bronze-Cer...
not least of which because its a certified PSU but also because it has the right type and number of connectors for you equipment and of course provides the raw power for the job ..... of course it might be a pound or two more in price but unlike the alpine unit it wont be overtaxed from the get go
06-03-2016 12:23 PM
06-03-2016 12:29 PM
06-03-2016 12:35 PM
Only 18A on the 12V line, probably why I am having issues. Also only a 4way mb connector, NB this was supplied fitted to with the motherboard & cpu.
Wondering if it is a typo on the spec of the CiT one, it says only 2A on 3.3&5V lines.
DC
Output
Max +3.3V +5V +12V1 -12V +5VSB
2A 2A 39A 0.5A 2A
500W
I assume it should be 20A. But at that it is 650W in total with everything maxed out.
