Graphics card advice
- Graphics card advice
22-02-2013 3:22 PM
Specs for this model can be seen here
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=...
The computer is mainly used for storing / viewing / and editing photographs plus a few fairly basic games.
Any advise would be appreciated
Chris
Re: Graphics card advice
22-02-2013 3:25 PM
I assume you are seeing problems
Are you running Win 7 64bit or 32bit
The other question is what graphics resolution is your monitor as that can seriously affect the recommendation
22-02-2013 3:29 PM
If you are though, it's probably worth a look at the low end of nVidia's 6 series: http://www.scan.co.uk/shop/computer-hardware/all/gpu-nvidia/1037/1038/1039/1057/1273/1301/1274/1188/...
Anything with an HDMI out socket on it should be capable of running basic (and older) 3d games up to and including say half life 2.
Hope that helps.
22-02-2013 4:27 PM
Quote Power Supply
300W
300W power supply
Will struggle if not fail to boot with anything too powerful, you might end up having to get a new PSU as well, so double check what you are buying
22-02-2013 8:17 PM
The images I am editing are fairly large at upto about 12MB
More often than not I'll be working with three or four images at once. I had assumed that a graphics card with maybe 1GB memory might speed things up a bit.
The games I am talking about are fairly trivial sort of stuff of the jewel quest and h.o.g. ilk.
One in particular I bought recently which freezes when run states "The program requires a minimum of a 256MB graphics card" From what I can gather, the "in built" graphics of my computer is 249MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
Had a look at scan.co.uk and came up with this
Asus NVIDIA GT 610 Silent Low Profile Compatible Graphics Card - 1GB
http://www.scan.co.uk/products/1gb-asus-gt-610-silent-pcie-20-%28x16%29-40nm-1200mhz-gddr3-gpu-810mh...
It doedn't say so on the above page but I read somewhere else that it is rated at 300w
What do you think? Using this card would I see any improvement in my computers performance?
Thank you all for your help and advice
Chris
22-02-2013 9:38 PM
Which graphics program are you using
How much spare hard drive space do you have
And an earlier question are you using Win7 64bit or 32bit
Note that that graphics card draws less than 30watts http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gt-610/specifications
It may also be worth checking the Virtual Memory settings
23-02-2013 12:30 AM
Using Photoshop Elements 9
Free disc space: 448 GB
According to the "View basic information about your computer" page in Control Panel
System Type: 64-bit operating system
Virtual Memory is set at 2815MB
As you've probably gathered by now, I'm sadly lacking in know-how of all this tech stuff.
I really do appreciate your help and patience.
Chris
23-02-2013 10:08 AM
How much memory is in your computer - the basic spec is 3GB with a maximum capacity of 4GB
Does windows report 2 hard drives C: and 😧 with the operating system in C: and data in 😧
Have you updated elements to 9.0.3
23-02-2013 10:33 AM
23-02-2013 11:02 AM
Memory 3GB
drive C: is marked as O/S and 😧 as HP_RECOVERY
and yes, Elements 9.0.3 installed.
ejs
Thanks. Is it save for someone of my limited ability to mess about with the BIOS setup?
Chris
23-02-2013 11:28 AM
My current W7x64 system (onboard motherboard graphics) shows 128MB Dedicated Video Memory but 1851MB of Total Available Graphics Memory and nothing I've tried has ever complained about "only" 128MB.
As noted above you may well be able to change the memory dedicated to graphics in the BIOS. Usually by pressing F10 or F2 at startup (press early, press often to paraphrase the Irish voting cartchphrase).
23-02-2013 11:30 AM
Increase the memory to 4GB and put in a graphics card with 1GB RAM - both will help
With respect to memory I suggest running the Crucial Memory tool http://www.crucial.com/uk/store/drammemory.aspx
For the graphics card any will do but you don't need low profile which actually won't fit in your case - compare the depth of the mounting bracket to a regular one
Regarding source for the graphics card - if you don't have free delivery Scan's delivery charges are very high
You should consider Amazon as you can get it with no delivery charge and any problems Amazon will sort it much better than other companies http://www.amazon.co.uk/s/ref=sr_nr_p_72_0?rh=n%3A340831031%2Ck%3Anvidia+610%2Cp_72%3A419153031&bbn=...
23-02-2013 11:32 AM
Quote from: Novocastrian Is it save for someone of my limited ability to mess about with the BIOS setup?
Usually. You will get asked to confirm any changes.
Just try and get into it and have a look round; see if you can identify anything relevant and report back what it is and what options there are.
23-02-2013 7:30 PM
Not too happy messing about with the BIOS, but I feel quite comfortable working with a hammer and a pair of mole-grips so I'll probably go for the graphics card option.
Cheers
Chris
25-02-2013 7:54 AM
Quote from: Novocastrian Asus NVIDIA GT 610 Silent Low Profile Compatible Graphics Card - 1GB
You realise that low profile means half height and you appear to have a full 'height' case (i.e. full-width in this context). I'm not sure, perhaps 'compatible' means you can replace the normal full-height mounting bracket with a half-height one. Perhaps you should check before you buy?
