Graphic card problem
- Re: Graphic card problem
20-12-2020 12:12 AM
For the past few weeks my desktop computer has been displaying a red warning message that my graphic card (GTX 650) is running at 350 rpm and a temperature of 40 c.
I have tried to alter the speed through the bios and additional software but with no luck, is it possible to repair the card ?
Accept it’s a old card....2012 era.....or am I just wasting my time and accept another card is the only option ?
20-12-2020 8:33 AM
You should be able to replace the fan on the card as that's your issue here.
20-12-2020 9:19 AM
20-12-2020 9:36 AM
Another thing you may want to consider @gleneagles is to give your card a dusting. If you're comfortable with it remove it from the machine and use a vacuum to clean it by placing the nozzle over the fan to extract the dust from the casing.
While you have this out you'll also get a measure of how easy it will be to replace the fan and the size needed.
20-12-2020 1:31 PM
Aye, a good thing to do periodically, especially if it's a tower on the floor.
For ease of access and a stronger suck, I've improvised a tool comprising a length of washing machine hose, garden hose, and a couple of bits of sleeving from the junk box to step down the diameter to 9mm.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
20-12-2020 2:01 PM
I use an air duster
20-12-2020 5:47 PM
I usually find blowing more effective than sucking, especially using an air hose attached to a compressor with one of these or similar.
20-12-2020 6:18 PM
40C is slightly above normal body temperature, so its probably a configuration error to say that's a warning?
26-12-2020 8:10 PM
If you are ok with dismanteling your pc and removing the card, give it a good clean. Check and clean the main cpu fan and heatsink while you're in there.
27-12-2020 3:38 PM
@RobPN wrote:
... especially using an air hose attached to a compressor with one of these or similar.
If you have a friend who is a dentist, he'll have something similar in his surgery, although you probably won't be allowed to take a computer into the surgery at the moment.
27-12-2020 5:23 PM
Lock-down or not, I don't think many dentists would be amenable to blasting a cloud of dust into their nice clean surgery.
