Google - is becoming annoying....!
- Google - is becoming annoying....!
07-11-2010 10:42 AM
that is the way I like to work it....... Problem is, google seems to have changed recently, when I minimise a page, and open a new google search page, all the minimised pages come back to full screen behind the new page.... which means that I have to minimise them all again before I can get back to my desktop...I am often opening up new fields of search, so this has become quite annoying..... I don`t need the minimised pages, UNTIL ... I.... Need them... that is why I minimise them....
how do I tell google to stop messing me about ?
Re: Google - is becoming annoying....!
07-11-2010 11:32 AM
but if I want to return to my desktop but other windows are in the way
with Vista
I press the keyboard combination keys
windows logo key + D
and press them both again to go back to what i was doing before
07-11-2010 3:10 PM
07-11-2010 3:42 PM
you then get one browser icon on the task bar, hover that and it shows the other open windows, complete with a red cros
sorry about that
07-11-2010 4:30 PM
It will probably be just the same in Win7, as it is a google problem.... not windows.....
08-11-2010 12:13 AM
08-11-2010 8:17 AM
This has only happened in the past week or so,
11-11-2010 8:54 AM
11-11-2010 3:50 PM
Only if you click on the cross in the top right corner, if you click the cross on the tab itself just that tab will close.
11-11-2010 7:58 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
