Google.com
- Re: Google.com
Google.com
26-11-2014 3:44 PM
Re: Google.com
26-11-2014 4:01 PM
Re: Google.com
26-11-2014 4:13 PM
Re: Google.com
26-11-2014 5:58 PM
I came across this recently on a friends laptop where the CMOS battery had expired. Replacing the battery and re-setting the time correctly solved the problem.
Re: Google.com
26-11-2014 6:40 PM
yup i just swapped all hardware into a new case , never noticed the date
Re: Google.com
26-11-2014 8:03 PM
Quote from: rongtw ... never noticed the date
I did of course mean time and date
Glad it was an easy fix for you
Re: Google.com
26-11-2014 8:26 PM
Re: Google.com
26-11-2014 8:42 PM
Re: Google.com
27-11-2014 8:35 AM
To be is to do - Kant
do be do be do - Sinatra
Re: Google.com
27-11-2014 8:54 AM
Re: Google.com
28-11-2014 12:38 PM
Quote from: PeterLoftus Do laptops have a CMOS battery I have a similar problem
Peter,
Yes they do. When you switch on, if the date is not right, the battery has gone.
On some machines you can access the battery without totally dismantling the case which unless you know how is a specialist job. After that some batteries are soldered to the mother board. The batteries cost very little, but fitting them could cost a small wedge.
Kevin
Re: Google.com
28-11-2014 8:50 PM
Thought I had malware
Its a HP Presario C700
Re: Google.com
28-11-2014 9:39 PM
Re: Google.com
28-11-2014 10:47 PM
Yes there is a manual included here as well!
I've also seen videos on YouTube
Big job - remove back, keyboard, screen, motherboard and a shed load of connectors just to change the CMOS battery lol
And I can see it through the access for the the memory but can't get to it
Re: Google.com
29-11-2014 9:34 AM
