Google.com
rongtw
Fixes: 12
Google.com
is it just me but for some reason Google.com search comes up as a untrusted site ?  i have never had this before
14 REPLIES 14
Fixes: 1,483
Re: Google.com
fine here.
rongtw
Fixes: 12
Re: Google.com
something strange Going on  Sad plusnet portal , and plusnet webmail now come as untrusted , Facebook & utube the same
RobPN
Fixes: 13
Re: Google.com
Is the time set correctly on your computer?
I came across this recently on a friends laptop where the CMOS battery had expired.  Replacing the battery and re-setting the time correctly solved the problem.
rongtw
Fixes: 12
Re: Google.com
DOH  Crazy
yup i just swapped all hardware into a new case ,  never noticed the date  Lips_are_sealed
RobPN
Fixes: 13
Re: Google.com
Quote from: rongtw
... never noticed the date
I did of course mean time and date  Wink
Glad it was an easy fix for you  Smiley
rongtw
Fixes: 12
Re: Google.com
strange tho as i didnt remove the Cmos battery , just unplugged everything and rebuilt in new Phantecks enthoo case  Cool
St3
Aspiring Champion
Fixes: 5
Re: Google.com
old age that mate
PeterLoftus
Fixes: 5
Re: Google.com
Do laptops have a CMOS battery I have a similar problem  Undecided
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
rongtw
Fixes: 12
Re: Google.com
Ste  Tongue Tongue Tongue Tongue
Fixes: 160
Re: Google.com
Quote from: PeterLoftus
Peter,
Yes they do.  When you switch on, if the date is not right, the battery has gone.
On some machines you can access the battery without totally dismantling the case which unless you know how is a specialist job.  After that some batteries are soldered to the mother board.  The batteries cost very little, but fitting them could cost a small wedge.
Kevin
PeterLoftus
Fixes: 5
Re: Google.com
Yes date keeps going wrong
Thought I had malware
Its a HP Presario C700 Smiley
Re: Google.com
@'PeterLoftus' - Does this help ?  -  How to Replace a CMOS Battery on a Compaq Presario C700
Wink
PeterLoftus
Fixes: 5
Re: Google.com
@purleigh thanks
Yes there is a manual included here as well!
I've also seen videos on YouTube
Big job - remove back, keyboard, screen, motherboard and a shed load of connectors just to change the CMOS battery lol
And I can see it through the access for the the memory but can't get to it  Grin
PeeGee
Re: Google.com
Am I pleased I have a Toshiba C855..... remove one screw and the memory/disc cover plate, replace the (now exposed) CMOS battery, refit cover and screw Cheesy Cheesy Cheesy
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
