Google Search changed
- Re: Google Search changed
01-04-2009 4:32 PM
EDIT - they have and I don't like it http://googleblog.blogspot.com/2009/03/two-new-improvements-to-google-results.html
2nd edit - you can opt out using preferences
01-04-2009 4:43 PM
01-04-2009 4:48 PM
If Google keeps at it they will drive me elsewhere.
01-04-2009 5:06 PM
Don't like it either, didn't think of looking in preferences!
01-04-2009 5:40 PM
01-04-2009 6:55 PM
01-04-2009 6:59 PM
01-04-2009 7:02 PM
I quite like looking to see what some of the suggestions might be, its sometimes a kind of mini-stumbleupon allowing you to find things that might be presented for search terms similar to the ones you intended using.
01-04-2009 7:37 PM
01-04-2009 9:49 PM
i installed eiSPELL add on for ie8 last night and on my first google today noticed the same but put it down to the add on
01-04-2009 10:55 PM
I would have no way of avoiding this with Google, simply because I refuse to accept cookies from it.
I use Scoogle (http://www.scroogle.org/cgi-bin/scraper.htm) and although it has its drawbacks (only a maximum of 100 results, and no equivalent of Google's Image search being two of them), it does delete all access logs within 48 hours and keeps no records of your search terms.
01-04-2009 11:05 PM
01-04-2009 11:23 PM
01-04-2009 11:30 PM
02-04-2009 7:22 AM
Just tried editing the search button on my Firefox, it seemed to have accepted Google.co.uk did a search on Braintree and it came up with google.com again and Braintree Massachusetts again
the English council web is www.braintree.gov.uk, the US one is www.townofbraintreegov.org/
