Google Maps
Fixes: 388
Google Maps
Here's one for the clever people. If I use Google maps on my iPad, it places me exactly where I am - at home (at the moment). However, if I open exactly the same program on my laptop, I am somewhere in Ealing, West London. Why?Huh
And before you ask, both the laptop and iPad are on Wi-Fi, with location services enabled.
13 REPLIES 13
Fixes: 480
Re: Google Maps
Your IPad will use either GPS or mobile masts, depending on the model, not WiFi, to determine your location, not ‘WiFi ‘.
Fixes: 388
Re: Google Maps
Good point @Baldrick1  - I had half-forgotten that, 😀  However, it still doesn't explain why the laptop thinks I'm in Ealing. It has never been anywhere near there, and although it is at least currently consistent, I have  'been' to Leicester, Derby and Chester in the past.
I am on a static IP (for the past four+ years) and at the moment am on one of Zen's Manchester PoP's
outcast
Aspiring Champion
Fixes: 19
Re: Google Maps
Just guess -
Zen do use a transit provider that has a data centre that is near Ealing.
Fixes: 388
Re: Google Maps
Thanks, @outcast - I'll check your graphic when or if it is released.
Fixes: 388
Re: Google Maps
Seen it now, @outcast . I get what you mean, but if I'm connected to Manchester, do I need to go via London? - bear in mind I'm no network expert, but...
I did a quick mtr to the BBC, but as I'M on IPv6, the hops after the Mcr PoP were just IPv6 strings, and I CBA to look them up.
outcast
Aspiring Champion
Fixes: 19
Re: Google Maps
Have you seen this news story today ? - Zen Internet ... 400 Gbps upgrade between Manchester and London
Fixes: 388
Re: Google Maps
I hadn't seen it - I don't visit TBB every day - but it makes sense. The only bit that worries me is the reference to AI, but there again, I'm not a great believer in the almost total reverence that technology is held by some.😀
Re: Google Maps
Has your mobile device ever used the internet connection which your lappie has?
mwwagain
Fixes: 4
Re: Google Maps
Google maps website only knows your IP address, so guesses based on that.  It means the AI is being singularly unsucessful at locating you which is probably a good thing.
Half the time Bing thinks I'm in Ealing, the rest in Leeds while Google says Reading.  That is for a fixed IP on fixed equipment - in Essex.
The fixed IP and equipment in Scotland is also usually thought to be in London - or sometimes Glasgow
Fixes: 388
Re: Google Maps
Fair enough, @mwwagain . The thing is, I move between Ealing, Nottingham, Leicester and somewhere in, I think Lincolnshire. However, I think @outcast has answered my question, and the query was only meant half-jokingly anyway - not a life-threatening situation. 😀
Fixes: 251
Re: Google Maps
This is another example of imprecise IP geolocation data.  Devices with GPS (phones and tablets) locate from real data.  Laptops or more to the point the service being used, relies on geolocation information related to the IP address … which especially if it’s a dynamic address, can be additionally variable.
Some services are smart enough to co-link connecting IP addresses with the GPS location of the connected device.  Which is fine until the address is reassigned.
Fixes: 388
Re: Google Maps
@Townman , merely for information, I am on a static ipv4 address - but - I suspect my ipv6 address, which is the one all my kit seems to prefer, is dynamic and does change occasionally, although even that used to locate me well away from Sheffield, but not always  quite as far away as Ealing.
ExForce9
All Star
Fixes: 11
Re: Google Maps
@jab1 wrote:
... my ipv6 address, which is the one all my kit seems to prefer, is dynamic and does change occasionally
On Zen, YOUR IPv6 will have a static prefix, and a dynamic suffix.
This means that you will have a static /48 subnet that is associated with your Zen account (and is the part that any geo-location service would use), but within your subnet you can have your devices select a specific IP address by various mechanisms (such as DHCPv6).  Therefore if your devices are changing their IPv6 IP addresses occasionally, then that is comparable with your IPv4 devices changing their DHCP allocated LAN address while the IPv4 WAN address remains static.
