Google Earth Pro
penneck
Google Earth Pro
When I turned on my computer earlier today, I found Google Earth had changed to Google Earth Pro. I didn't knowingly ask for Google Earth Pro, so I am a bit annoyed that this has happened. I have tried using it, but cannot figure out how to get it to show me that basic thing, the earth, so I cannot see the roads and houses etc in towns. All I can see is a skeleton view of the globe, which if I go in closer, shows (1) place names, (2) where the coast is, (3) county boundaries - but all only as skeletal things. I can turn on Roads which gives me roads and road numbers, but still only as a skeleton. Investigation suggests Pro wants Google Chrome, which I don't want if I can avoid it. Anyway, I don't want to install Chrome only to find that having Chrome isn't the answer.
Is there any way to either get back to the Google Earth I had only yesterday, or solve the problem of the missing ground in Pro, without installing Chrome?
Thanks for any help
6 REPLIES 6
VileReynard
Fixes: 20
Re: Google Earth Pro
Have you tried https://www.google.co.uk/maps
penneck
Hello VileRenard. I have tried Google Maps as you suggested. It isn't as good as the old version of Google Earth. I cannot get in as close.
My preferred position would be to get back to the old Google Earth that I had until today, but thanks for your suggestion
jaread83
Fixes: 81
Might be able to download previous versions here:
https://support.google.com/earth/answer/168344?hl=en
penneck
Thankyou Jaread83. I have had to load version 6.2 to get the old version I had before. The streetview does some funny distortions occasionally, but I think it is better than the latest Earth Pro
Thanks everyone. Can we consider this closed now, please
jaread83
Fixes: 81
Glad you managed to get it sorted Smiley just make sure in the application to turn off automatic updates so it doesn't upgrade to Pro again.
penneck
Thankyou jaread83. I have spent a short while looking at the old Google Earth I have on my pc now, but have failed to find any way of controlling updates. However, I did discover that Google Earth has a user forum, and I found on that forum other people complaining about this uninvited change to GE Pro (and the problems it has caused them). The forum mentioned that there is a 'cure' for the problem I had with GE Pro - change from OpenGL to DirectX. Wouldn't it be nice if they had mentioned that in their intro to GE Pro. If they did, I didn't see it. Now where did I leave my white stick.
Onwards and upwards. Thanks once again
