Google Chrome
rena
Google Chrome
Sorry not sure where to post this!  I use Google Chrome but for the past few days I haven't been able to get into any websites. I get various messages like telling me to check my broadband connection (but I am able to use IE), or 'the app is currently unreachable' or 'google cannot reach my webspace' ( I changed my webspace to google search then yahoo, but none of them worked).  I have no idea what to do. I looked at the Google help page and it said to look under the bonnet, but I checked and it's the same as my daughter's. It also said to make sure the laptop security allows Google Chrome in, but i'm not sure how to do this?  I installed McAfee from Plusnet about 10days ago and it worked ok, and it's only in the past 3/4 days that I haven't been able to get Chrome to connect to any sites. I've also uninstalled and installed it 3 times. Could someone please tell me how to get Chrome working again? thanks
8 REPLIES 8
Oldjim
Resting Legend
Fixes: 63
Re: Google Chrome
moved to Windows as it is clearly a problem with it.
Can you advise the version of Windows you are using
rena
Re: Google Chrome
It's Windows 7.  Thanks for moving it Oldjim (wasn't sure where to put it, it mentioned broadband so I put it in there)
Oldjim
Resting Legend
Fixes: 63
Re: Google Chrome
As a cross check can you try using Firefox and see if that works
In Internet Explorer are the LAN settings like this picture
rena
Re: Google Chrome
hI Jim, Firefox works, and the settings are the same as your pictures.  Thank you for trying to help me but I have to go out just now. Will try to get back tonight or tomorrow.
adagio
Re: Google Chrome
Firewall settings?
Moncrieffe500
Re: Google Chrome
maybe try a system restore to 10 days ago when it worked?
rena
Re: Google Chrome
Sorry, don't really know much about Firewalls. It's McAfee (from Plusnet). It was Windows firewall but McAfee seems to have automatically 'disabled' the Windows one. I looked at the settings but they don't mean anything to me. I don't know where to look to see if any sights are blocked. The funny thing is now that any new sights I looked at (so far) are now working, but ones that I have been using all the time like Facebook and Smallworlds (my daughter) don't work!
Oldjim
Resting Legend
Fixes: 63
Re: Google Chrome
Do the old sites just not work when using your existing favourites or also if you type in the address yourself
