Google BLACK bar
VileReynard
Seasoned Pro
Fixes: 11
Google BLACK bar
I've discovered that www.google.co.uk have started using a manky black bar on the search site.
Can this be removed e.g. with the Stylish FF plugin?
Re: Google BLACK bar
It's pig ugly and difficult to read.  Angry
Steve
Seasoned Pro
Don't like It myself either to be honest. Maybe I need a thicker browser Grin
If life gives you lemons, make lemonade.
Fixes: 62
    @-moz-document url-prefix("http://www.google.co.uk/") {
    #gbx4 {
      background: white !important
    #gbz a,
    #gbz span,
    #gbg span {
      color: blue !important
    a.gbzt:hover,
    a.gbgt:hover {
      background: rgb(240,240,240) !important
    a.gbzt:active,
    a.gbgt:active {
      background: rgb(235,235,235) !important
Changed the text to black as I prefer it.
Note you need to create a separate rule for other Google pages such as maps
edit - two more } added to make them balance
VileReynard
Seasoned Pro
Fixes: 11
Jim - you're an absolute star!  Grin Grin Grin Grin
note - I don't know if it's needed but I added a couple of '}' lines to make the brackets balance.
I use google.com and they've done the same there.  Not impressed Sad
VileReynard
Seasoned Pro
Fixes: 11
Install the FF addon  "Stylish", which allows you to modify style sheet behaviour on a per site basis.
Use Jim's script to make it work.
Steve
Seasoned Pro
You may have heard talk of a mysterious black bar appearing on the top of Google.com. Or you may have even seen it yourself. No, you weren’t hallucinating. It was a sign of something about to show itself. Something big. Google+.
What is Google+? It’s the super top-secret social project that Google has been working on for the past year. You know, the one being led by General Patton (Vic Gundotra) and General MacArthur (Bradley Horowitz). Yes, the one Google has tried to downplay as much as humanly possible — even as we got leak after leak after leak of what they were working on. Yes, the one they weren’t going to make a big deal about with pomp and circumstance. It’s real. And it’s here.
Sort of.
Info ....http://techcrunch.com/2011/06/28/google-plus/
Grin
VileReynard
Seasoned Pro
Fixes: 11
I call it Google-minus  Grin
If I didn't have the black bar removal code (from OldJim), I'd be looking for a different search engine.
It was either that, or start using a text-only browser...
