Google Analytics Opt-out Browser Add-on
- Re: Google Analytics Opt-out Browser Add-on
28-05-2010 4:56 PM
28-05-2010 4:57 PM
28-05-2010 7:39 PM
28-05-2010 8:36 PM
28-05-2010 8:46 PM
28-05-2010 8:46 PM
Until now:
- I don't trust Google...
- Google Analytics uses scripts by Google...
- Therefore I don't trust Google Analytics
Now:
- Google Opt-out uses scripts by Google...
- Therefore I don't trust Google Opt-out.
I don't see what's changed.
28-05-2010 9:28 PM
@shutter I hope so aswell.
Working fine here on FF 3.6.3. Linux Mint Isadora
28-05-2010 9:37 PM
Quote from: Steve There's Method to the Madness JohnJ...
Exactly....
Method and Madness.
28-05-2010 9:56 PM
* using Add block plus
28-05-2010 10:03 PM
Quote from: Peter * using Add block plus
Ditto
28-05-2010 10:12 PM
For those with add block plus, click on the ABP logo and look for the hidden webstats.plus.net URL which includes your IP address.
28-05-2010 10:57 PM
At least with Plusnet,, the javascript in sdc_tag.js easier to read than the Google maze of code.
So, apart form stuff that I expect would be available from the web server logs (including the IP address?), the script also seems to gather; screen size, colour depth, flash version, Java enabled and Javascript version.
It doesn't bother me, but I think sdc_tag.js may be the target to aim Adblock Plus at, if the above information was felt to be sensitive.
It doesn't bother me, so I've not blocked the plusnet tracking components.
29-05-2010 6:03 PM
thats whats broken speedtester for me
maybe
i'll get back on this
29-05-2010 7:38 PM
I use ABP and just blocked this what you have said, Is there anything else that's invading my privacy that I should be aware of?
Quote from: Peter And don't forget to block PlusNets alternative (sneaky) method of tracking your access to their webpages.
30-05-2010 5:15 PM
it is so well hidden I can`t see it.... I have managed to get http://community.plus.net/sdc_tag.js on the filter though !..
as Steve M says..... Anything else?
