Good degragmenter for WinXP-SP2
- Good degragmenter for WinXP-SP2
26-09-2007 9:40 PM
What defrag programs do people here use?
Re: Good degragmenter for WinXP-SP2
26-09-2007 9:52 PM
26-09-2007 9:58 PM
If FAT32 you need to defragment regularly. With NTFS you often don't see a difference after running it so I rarely bother.
I used to use the defragger that came with norton systemworks but that got too bloated so ditched it.
I now use O&O Defrag V8 pro from O&O Software. It has a mode where it will run automatically in the background whenever it detects the filesystem needs to be defragmented, so it only runs for a few minutes in the early hours rather than 10 or 20 or more if run from time to time.
26-09-2007 9:59 PM
26-09-2007 11:05 PM
26-09-2007 11:16 PM
27-09-2007 12:35 AM
built in defrag tool regardless of being designed by the same company
Ive used O&O defrag in the past too which is a very good program and comes highly recommended by many
27-09-2007 7:35 AM
27-09-2007 7:37 AM
I can vouch for the efficacy of Diskeeper - I installed it on my mother-in-law's PC as she didn't know how to defrag the hard drive (I had to do it whenever I was there). Set it up to defrag automatically in the background and I've not had to do a "manual" defrag since.
It also allows you to do boot time defrags and a manner of other things including defragging and resizing the MFT (all dependent on which version you buy).
edit: typos
27-09-2007 10:52 PM
I have occasional crashes, and wondered whether a decent defrag program might sort them out. I've tried everything else, so in an attempt to avoid reinstalling WinXP, I thought I'd try a decent defrag program.
Looks like Diskeeper seems the most popular one at the moment, although I was slightly concerned that download.com's review said that it added 4 minutes to the boot-up time.
27-09-2007 11:14 PM
Quote I was slightly concerned that download.com's review said that it added 4 minutes to the boot-up time.
Don't know where they got that from. Both my WinXp laptop and my Vista desktop are running Diskeeper Pro and both boot up in under 2 minutes.
Perhaps they were referring to the bootime defrag. This is something you can set to run at the next boot (you have to set it each time you want it to run, it won't run automatically at each boot) and adds about 4-5 ninutes to the boot time.
I've only ever done 1 boot time defrag on my machines in the past 6 months.
30-09-2007 6:01 PM
My PC crashed just before the BIOS memory check the other day, so I doubt that any defragmeter will help. I opened up the case, cleaned out all the dust, removed and refitted all the connectors, and removed, and refitted, the RAM. I also cleaned the RAM connectors. Hopefully that will help, otherwise I think I'll buy a new motherboard.
Thanks for your posts, I'll consider buying Diskeeper once my PC has settled down.
30-09-2007 10:36 PM
It is likely to be your power supply especially if you have added any extra components.
The PSU is most stressed by the power-on surge.
30-09-2007 11:36 PM
PS: Sorry for going slightly off topic.
PPS: I'm still not getting e-mails telling me that there have been replies to threads that I'm interested in.
01-10-2007 12:25 AM
