Gold plated connector contacts?
chuffchuff
John Lewis are advertising a Belkin Hero Cat6 Ethernet cable here
which claims "features gold plated connector contacts to deliver maximum conductivity so that data transmission is fast."
Any truth in the claim?
9 REPLIES 9
chenks76
All Star
Fixes: 12
Re: Gold plated connector contacts?
hocum
mikelahey
Fixes: 12
I concur with @chenks76, waste of money. Not required for cat 6 to work.
rongtw
Fixes: 12
Gold makes minimal difference , just buy a standard connector
VileReynard
Fixes: 20
The cable will run at either 1,000Mbps or 100Mbps - nothing in between.
twocvbloke
Nope, it all goes back to the gold-plated, oxygen free (which is a scam in itself as copper wire by nature is oxygen free!!) speaker wire thing, works for analogue signals, but digital signals are just On and Off at a set voltage, anything spurious on the wires (such as RF interference) is ignored by the hardware thanks to tolerances set by the controllers which will only accept an incoming signal if it meets the criteria, kind of like a bouncer for a nightclub...
The gold plated thing is just to get uneducated mugs to buy higher-priced items to keep the manufacturers' profits up as they laugh all the way to the bank, as long as the wire is of a decent thickness, and isn't made from chinesium wire (the Copper-coated easy-break aluminium wire) then it'll work... Smiley
w23
Fixes: 4
Gold plated connectors ARE a good thing for most signal cables (analogue or digital), they won't improve any signal as such but non-plated connecting surfaces (the interface between plug and socket) are susceptible to oxidation and therefore can fail simply due to 'dirty contacts', gold plating is one of the most resistant to this effect.
Most CAT5/5e/6 cables (telephone cables, modem leads etc. as well) have gold plated connectors, only the cheapest ones don't.
Call me 'w23'
twocvbloke
Yes, most connectors are gold-plated, but aren't sold under the "Improves abc by xyz cos it's gold plated!" nonsense, it's the ones that are that are taking the pee with peoples' money, using it as a way to make it more expensive and therefore "worth buying" when in reality it's no better than something from a pound shop...
Luzern
Fixes: 9
That JLP should be advising that way, dismays me! Have they got themselves infiltrated by You-Know Who?Roll_eyes
Then again perhaps some of their customers "must have the best".Crazy3
198kHz
Fixes: 41
Probably not, otherwise it would  provide more detailed data, better three-dimensional resolution. and cost around £75Wink
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
