Going back from Windows 10 breaks scheduled tasks
ReedRichards
Fixes: 25
I've just become aware of an unpleasant side effect if you upgraded to Windows 10 then changed your mind and reverted back to Windows 7 or 8.1 (by the obvious router of choosing the 'Go back to previous build' option).  If you run Task Scheduler then a huge slew of tasks show as corrupted (and so do not take place).  In the long term this could compromise the security of your computer.
Fortunately a kindly soul has developed a fix which is here: https://repairtasks.codeplex.com/ .  I've run this twice for two different computers that have gone back from 10 to 7.  It worked in both cases (there were two stages to fix all the scheduled tasks).
