Go Wireless
xixi
Go Wireless
Does anybody know how to setup the wireless connection? I had a one before with my previous broadband provider, when I tried to setup Plusnet Wireless it seems corrupted with my old one. Tongue
Cheers,
1 REPLY 1
Oldjim
Resting Legend
Fixes: 63
Re: Go Wireless
Would it be correct to assume that you are using a Plusnet supplied router and you want to be able to access it using wireless.
If so please advise which operating system you have on the computer
