Getting my stuff of Ubuntu
- Getting my stuff of Ubuntu
07-10-2015 9:09 AM
Any suggestions on either fixing this error or how to access the folders on the old HDD? I currently have a live cd running but when I try and access the folders I need I don't have sufficient permission. tried sudo -i nautilus but still no joy. Just want to flick through my folders to make sure I haven't left anything important on there to get off onto usb stick.
Re: Getting my stuff of Ubuntu
07-10-2015 9:16 AM
07-10-2015 1:24 PM
Just need to get these pictures off my computer.
07-10-2015 1:41 PM
1) Original boot:- Use CTRL+ALT+F1 to get into a command line - you won't be able to run a GUI but you can list directories etc
2) Use Live DVD - but you have been trying to run nautilus on the live DVD version of \home, so
1. Try sudo nautilus (note: ignore massive error messages)
2. Browse to appropriate device/directory
3. You might need to press CTRL+C when you return to terminal screen
4. Don't forget to unmount your drive.
3) Try a different live distro e.g. Mint but note that the file manager is normally "nemo"
07-10-2015 1:45 PM
07-10-2015 2:24 PM
The folders were locked but when I transferred them over to my XP computer I can access the pictures again. currently uploading them all to my one drive account which was what I should have done to start with!
I think I'm safe enough to do a total wipe now.
07-10-2015 4:29 PM
I have two HDD's, a 120gig and a 80gig. Previously I had my 80gig with a ext4 / with a 3gig swap which was at the end of the partition. Decided to wipe this and put the 3gig swap at the start of the partition. So far I have
80gig
3gig swap
77gig / boot
120 gig /home
obviously at some point the grub loader must be looking for something else after changing the 80 gig about. How do I sort the grub out to boot from the right place?
07-10-2015 5:31 PM
Are we talking about an EFI-BIOS type system or a traditional MBR type system?
Secondly I presume we are talking about GRUB2, not "GRUB legacy"?
Since I haven't broken GRUB for years
I believe those instructions are for a DOS-type partition table (512 byte type) - I'd suggest you use the live CD method of fixing your system.
Sorry I'm not more helpful.
BTW Since you've just done a reinstall, you might as well do a re-reinstall - unless this is for educational reasons!
07-10-2015 6:19 PM
Easiest way is reboot from cd again and follow the instructions from above post.
07-10-2015 6:46 PM
It never gets used though.
I'm having a tough time using more than 2GB of my 8GB RAM
I've got 2 x 1TB disks & I've left 184GB unallocated on one disk & 582GB unallocated on the other.
Cos I don't know what to do with space.
BTW I've allocated 20GB for / but only used 42% of it.
I've allocated 160GB for /home but only used 12% of it.
So @AVG probably doesn't need 77GB for / on one of those disks.
My suggestion would be 20GB for / and 57GB for a directory which could hold data backups of disk 2
For example see http://backup2l.sourceforge.net/
07-10-2015 6:53 PM
I have :
1x 120Gb ssd / & /home 20 & 100Gb with 53% & 31% used
1x 2TB with my data on it 88% used
1x 2TB with M$ on not mounted.
Note NO swap, 8Gb ram
The SSD is overkill but it was on offer at Crucial earlier. Normal boot was <30s now is ~15s, M$ boot is ~5 min to a usable desktop ;-[
07-10-2015 7:38 PM
Quote from: Hairy So you have installed, backed up then moved partitions about? Any particular reason for that? Why a 3Gb swap? I tend to not have a swap any more, unless the pc has <1Gb ram.
Was actually your fault HB
The systems an old athlon with 3gig of ram, probably just standard mbr. I chucked in a XP disc before and restored the MBR hoping I could start from fresh but at the moment I've been getting read errors on the install disc, its been working perfectly all day.
Not going well.
08-10-2015 12:57 AM
So it doesn't matter where you put it.
08-10-2015 9:32 AM
I recently needed to fix GRUB2 but for an opensuse/win7 dual boot. A relatively easy task of running a boot manager from UBCD to get the installed Linux to run and resetting GRUB2 by running the boot loader module in YAST (a system management tool)
It's not perfect, as my laptop now offers opensuse and three win7s (the "hidden" boot partition, the Win7 partition and the manufacturer's recovery partition
Phil
08-10-2015 12:03 PM
Eventually I got things working using only one HDD and set up the way I wanted. Bit of follow up on the original problem which would have save me a load of heartbreak. It seems that an updated nvidia driver was causing the messed up desktop issue which I cam across by chance. I always used the 304...something drivers which have worked ok but now for some reason they are screwed up. Once I had everything up and running I tried using 304.128 proprietary which screwed my desktop and made it laggy.
ctrl-alt-f2 before going into desktop
$ apt-get remove --purge nvidia*
$ reboot
Then went through the list of drivers until one worked, the nouveu ones worked best but I have no control over my fan speed which runs flat out so had to revert to 173.14.30 legacy drivers. Not sure if these are best for my agp 6800gt card but at least they are working.
