Getting a wireless connector
- Getting a wireless connector
11-02-2010 9:44 PM
I have just signed up to broadband with plusnet and I need a wireless connector for my PC. Anyone know if they sell them and cost etc'
I have an Inventel connector that I used before with my orange connection but I don't know if it will work with the thompson router they are sending.
Also I don't know if the router will have an ethernet input so I can at least get set up until I get a wireless connector that works.
2 REPLIES 2
Re: Getting a wireless connector
11-02-2010 9:49 PM
yes it has 4 ethernet ports
The Inventel should work as it has wpa encryption
12-02-2010 12:25 PM
Thank you for the quick reply.
I have ordered a new wireless adapter because the computer I am using for this new connection is running on Vista 64 bit and the Inventel adapter doesnt work with Vista. I tried getting drivers for it but it was all a waste of time so I've got a new one coming that is Vista 64 bit compatible.
Thanks for your help.
