Getting a Vista laptop and a laptop with Linux together as network - how?
- Getting a Vista laptop and a laptop with Linux tog...
11-10-2009 7:07 PM
Right - now have a shiny Dell laptop with Vista[which at some point will be upgraded to W7] and old Sony with Linux Ubuntu on it. I use a wifi printer and that is linked to both computers via my router. Can I link the 2 computers so that I can send files to one from other? or do I still use a flashdrive and take it upstairs and plug it in the other laptop? am I just wishing to be lazy or is it possible please?
Re: Getting a Vista laptop and a laptop with Linux together as network - how?
11-10-2009 7:59 PM
Quote Can I link the 2 computers so that I can send files to one from other?
Yes, you should be able to. You use the samba package(s) on the Ubuntu laptop to provide Windows file sharing facilities.
See here for some starting information https://help.ubuntu.com/community/SettingUpSamba
I certainly use it to provide network file access between my Ubuntu m/c and and both Win2k & XP systems.
I've no direct experience of Vista but it shouldnt be a problem AFAIK.
Hope that helps get you started.
11-10-2009 8:05 PM
Since the shiny new computer has Windows on it, I suspect you'd prefer to use Windows protocols:-
Have a look at the SAMBA Linux package which allows Linux to see shared drives on your Windows computer.
This also allows printing to a printer attached to a remote PC - if you had one.
More simply, you could set up FTP servers on your PC's (easy on Linux, not sure about Windows).
This would allow you to send data files in between your PC's.
Simplest of all, for occasional use with smallish files and spare internet allocation would be to use a free service
such as https://www.getdropbox.com/help (there are others) which allows you to synchronise files across
multiple computers.
11-10-2009 9:29 PM
To make it easy and since you are behind a firewall (your router) click on Guest Access as well, and the "Allow other people to write" tick box. This allows you to read/write to the Ubuntu box from the WIndows box, From there click on Network (under Explorer) and then entire network/Workgroup and you should see the Ubuntu machine name appear.
The reverse I will allow someone who uses windows to do
13-10-2009 5:00 PM
13-10-2009 5:22 PM
13-10-2009 6:00 PM
Also check that the windows firewall allows the local network.
13-10-2009 6:32 PM
am using Kapersky so their firewall is on instead of Windows?............
13-10-2009 6:42 PM
Other to check is you can ping the Ubuntu machine by name, open a command prompt and type in ping <name of Ubuntu machine> You should get 4 lines of pings back with 100% success if not then we need to look deeper.
13-10-2009 6:47 PM
13-10-2009 7:19 PM
ping xxxxx(where xxxxx is either the name or ip address of the Linux PC).
This is a good way of proving a connection between any two machines.
13-10-2009 7:26 PM
This will open a black screen with a C:> type prompt in it,
Type in "ping " and then the name of the other computer,
example:-
ping torry
PING torry.lan (192.168.1.71) 56(84) bytes of data.
64 bytes from Torry.lan (192.168.1.71): icmp_seq=1 ttl=64
64 bytes from Torry.lan (192.168.1.71): icmp_seq=2 ttl=64
64 bytes from Torry.lan (192.168.1.71): icmp_seq=3 ttl=64
64 bytes from Torry.lan (192.168.1.71): icmp_seq=4 ttl=64
--- torry.lan ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3
rtt min/avg/max/mdev = 0.134/0.164/0.178/0.019 ms
Here torry is the name of another pc in my network.
You should see something like the above.
14-10-2009 12:00 PM
14-10-2009 1:45 PM
OR on the Ubuntu machine open a terminal (Applications/Terminal) and type in ifconfig
you should see something like this-
ifconfig
eth0 Link encap:Ethernet HWaddr 00:1a:4d:92:16:d0
inet addr:192.168.1.67 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::21a:4dff:fe92:16d0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:74842606 errors:0 dropped:0 overruns:0 frame:0
TX packets:60131908 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2012726679 (2.0 GB) TX bytes:982972309 (982.9 MB)
Interrupt:254 Base address:0xe000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1459 errors:0 dropped:0 overruns:0 frame:0
TX packets:1459 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:176893 (176.8 KB) TX bytes:176893 (176.8 KB)
The bit I have highlighted is the ip address of this machine (Running Mint but basically the same)
On the Vista machine open the cmd window (see above) and type in ping <What ever your Ubuntu machine says is its ip address>
If it returns something like I have posted above for torry then we are a little further forward. If it just says IP address not found or similar then the firewall may be blocking the local lan.
18-10-2009 4:31 PM
eth0 Link encap:Ethernet HWaddr 00:01:4a:c1:c4:27
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
So no number shown?
