Gateway TFT Monitor-Speaker Bar
community
Hi
Here's a teaser for you..
I am trying to locate a Speaker Bar which was an optional extra with the Gateway TFT 19" Monitor I bought last year from Staples.
I have been to Staples,to Gateway, to TigerDirect, to MiscoUk without anyone knowing what I was talking about! Yet the add-on (which is added to the monitor stand) appears in the User Manual for the monitor.
Does anyone out there know what I am looking for? Huh
2 REPLIES 2
Strat
Fixes: 565
Re: Gateway TFT Monitor-Speaker Bar
Something like this?
Then again maybe you won't want it
The review sample I got was pretty good, only the USB ports and occasional tearing were the downsides. Then there was the speaker bar which never quite snapped into place and wouldn't stay put,
community
Thanks Strat
That's exactly what I was looking for but after reading the reviews, I think I'm going to pass on it!!
