Gadgets
- Gadgets
Gadgets
21-08-2014 8:10 AM
its not a major problem ,,, but a annoying one
Re: Gadgets
21-08-2014 12:11 PM
Quote Gadgets have been discontinued
Gadgets are no longer available on our website because the Windows Sidebar platform in Windows 7 and Windows Vista has serious vulnerabilities. Microsoft has retired the feature in newer releases of Windows. Gadgets could be exploited to harm your computer, access your computer's files, show you objectionable content, or change their behavior at any time. An attacker could even use a gadget to take complete control of your PC. If you're concerned about the safety of gadgets you’ve downloaded, find out more about gadgets and steps you can take to protect your PC.
Re: Gadgets
21-08-2014 12:22 PM
will see if there is any alternatives
Re: Gadgets
21-08-2014 1:02 PM
I have not got the sidebar activated but I do have the weather gadget on the desktop for two locations. I will add that this is the gadget pre-installed with W7 and not downloaded.
Forum Moderator and Customer
Re: Gadgets
21-08-2014 1:37 PM
and I am keeping my gadgets
Re: Gadgets
21-08-2014 1:47 PM
Seems there's no need to be overly concerned.
Re: Gadgets
21-08-2014 1:52 PM
e.g. http://news.softpedia.com/news/More-Windows-9-Details-Leak-New-Taskbar-a-More-Flat-Look-Desktop-Gadg...
Re: Gadgets
21-08-2014 11:02 PM
Quote from: rongtw MMM interesting Strat but i like to see a clock & calendar on my desktop
Start > Run > sidebar.exe
That should see you right without restarting
Re: Gadgets
22-08-2014 8:34 AM
what i eventually did was add remove progs/ windows features removed sidebar , restart then enable sidebar
Re: Gadgets
22-08-2014 9:39 PM
Quote from: Oldjim and I am keeping my gadgets
Indeed I have also kept mine but I use the same ones that I've had for years and no new ones. Clock, cpu / ram monitor, local weather, clipboard manager and a calendar.
Re: Gadgets
22-08-2014 9:47 PM
Run
%systemroot%\syswow64\regsvr32 %systemroot%\syswow64\vbscript.dll
