GTX 970
- GTX 970
GTX 970
21-10-2015 2:32 PM
anyone got one ?
Re: GTX 970
21-10-2015 4:59 PM
Re: GTX 970
21-10-2015 5:12 PM
Re: GTX 970
21-10-2015 5:24 PM
Re: GTX 970
21-10-2015 6:14 PM
Re: GTX 970
21-10-2015 6:15 PM
Re: GTX 970
21-10-2015 7:44 PM
Re: GTX 970
21-10-2015 10:05 PM
Re: GTX 970
21-10-2015 11:37 PM
im now thinking about getting this one http://www.scan.co.uk/products/4gb-evga-gtx-970-ftwplus-with-acx-20plus-pcie-30-(x16)-7010mhz-gddr5-...
Comes with backing plate which protects it and its supposed to be cooler, also the evga uses less power and give better perfomance from what im reading.
Re: GTX 970
22-10-2015 9:25 AM
http://www.scan.co.uk/products/4gb-asus-gtx-980-direct-cu-ii-oc-strix-pcie-30-7010mhz-gddr5-gpu-1178...
Re: GTX 970
22-10-2015 10:26 AM
http://www.scan.co.uk/products/4gb-evga-gtx-970-ssc-acx-20plus-pcie-30-7010mhz-gddr5-gpu-1190mhz-boo...
The SSC has a better voltage regulator, better cooling and better port layout. Than the SC.
oh and the ftw+ you linked to thats a good choice also, that also has the above improvements. (not the plain ftw without the +)
Re: GTX 970
22-10-2015 6:25 PM
Re: GTX 970
22-10-2015 9:28 PM
Re: GTX 970
23-10-2015 8:21 AM
I would cancel the order and swap for the SSC, the price is very similar but the improvements are significant.
You havent said what resolution you be playing at, but if its 1080p then the 3.5gig wont be an issue.
Re: GTX 970
25-10-2015 11:08 AM
