GNOME 3.0
- GNOME 3.0
Re: GNOME 3.0
05-04-2011 12:13 PM
It booted the kernel (command line display)
But it just sat there after about 10 minutes, displaying a green 'L' with 5 moving green dots.
This is on a normally Ubuntu PC.
Keep trying.
Re: GNOME 3.0
05-04-2011 12:24 PM
It maybe simple for those that know, but for ordinary end users, all they want is a file they can click, and a PPA fulfils that requirement.
Quote from: Ben I must admit I don't get PPAs. It just seems like an automated build of a .deb from source, which is really easy to do with a few commands, and no uploading.
Re: GNOME 3.0
05-04-2011 1:58 PM
As to a Mint 10 DVD failing to load - did you verify the download hash? Only ones I have had fail on me like that are the Fedora ones
Re: GNOME 3.0
05-04-2011 3:29 PM
Re: GNOME 3.0
05-04-2011 4:05 PM
Re: GNOME 3.0
05-04-2011 4:25 PM
You are letting your own experience and knowledge blind you to the lack of experience and knowledge of many others and what people without your experience and knowledge find easy as opposed to what you find easy.
Re: GNOME 3.0
05-04-2011 4:33 PM
Quote from: Hairy As to a Mint 10 DVD failing to load - did you verify the download hash? Only ones I have had fail on me like that are the Fedora ones
Tried another download and a fresh DVD and it worked.
I don't usually bother doing md5 checking...
Whilst I'm not (yet) a mint fan, at least the window controls etc are in the "right" places...
Re: GNOME 3.0
05-04-2011 4:37 PM
Using a Personal Package Archive (PPA), you can distribute software and updates directly to Ubuntu users. Create your source package, upload it and Launchpad will build binaries and then host them in your own apt repository.
Re: GNOME 3.0
05-04-2011 6:00 PM
Re: GNOME 3.0
05-04-2011 6:04 PM
I wouldn't want to go back to the Windows way.
Re: GNOME 3.0
05-04-2011 6:09 PM
Re: GNOME 3.0
05-04-2011 6:10 PM
Quote from: A I don't usually bother doing md5 checking...
I use DownThemAll and just paste the md5/sha1 hash into the box provided - saves checking it after manually.
Re: GNOME 3.0
05-04-2011 7:40 PM
But that's Plusnet's "traffic shaping".
Re: GNOME 3.0
05-04-2011 7:48 PM
Re: GNOME 3.0
05-04-2011 9:07 PM
Distro torrents always come at line speed - typically 450KBps (my line isn't dramatically high speed).
Downloads from "download" sites get severely throttled at different speeds in the daytime.
