G.dmt stuck
- Re: G.dmt stuck
G.dmt stuck
26-09-2016 11:40 PM
Hi all.
I am new person with plusnet but hope i'll stay longer and enjoy plusnet's service unlike other provider
I moved recently from BT and noticed my profile is set to G.dmt now. This affects my poor broadband and I am struggling watching tv online and do not enjoy browsing or watching youtube etc.
With profile ADSL2 i could get up to 3.7 - 3.8Mbps download after syncing when in the meanwhile with G.dmt only 2.2 - 2.4
I can not express my sadness. Its like a being in stoneage even having 3.7Mbps.
In my 2nd home in East Europe I have 600Mbps download/upload though. Its like driving sports car all the time and one day you have only a pair of shoes to walk.
If someone could jump in and help me get back to ADSL2 - would be much appreciated.
Re: G.dmt stuck
26-09-2016 11:50 PM
My BT diagnostics test
1. Best Effort Test: -provides background information.
Download Speed | |
2.12 Mbps |
0 Mbps | 4 Mbps Max Achievable Speed |
Download speedachieved during the test was - 2.12 Mbps For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps. IP Profile for your line is - 2.48 Mbps |
Upload Speed | |
0.38 Mbps |
0 Mbps | 0.83 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 0.38Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Re: G.dmt stuck
29-09-2016 11:56 PM
Re: G.dmt stuck
30-09-2016 2:50 PM
There is no real difference between ADSL1 & ADSL2 - except that ADSL2 can make use of higher frequencies to give better bandwidth. A long line cannot use higher frequencies, so it "performs" as ADSL1.
Re: G.dmt stuck
30-09-2016 4:49 PM
You're thinking of ADSL2+. ADSL2 has numerous minor improvements over ADSL1, it uses the same frequencies, ADSL2 and ADSL1 both going up to 1.1MHz.
Re: G.dmt stuck
30-09-2016 5:51 PM
I dont know a lot about frequencies, noises and other things so can not comment why ADSL2+ is much better and how similar ADSL1 is to ADSL2.
But I know that being with BT and setting router in ADSL2 mode I had better speeds than I have now with ADSL1 which cannot be changed at the moment.
I had a chat on the phone with 1 of technical members today and looks like he made some changes which should come into action on the 7th Oct. The profile is set up to ADSL2+ now as I was imformed.
It is likely my previous BT account also was set as ADSL2+ but router was connecting in ADSL2 mode all the time where in some cases can better than ADSL2+
So fingers crossed now and I am expecting for a change on the 7th Oct
Re: G.dmt stuck
04-10-2016 1:19 AM
Oh God!
Never ending problems...
I am on ADSL2+ but it seems IP profile is banded. 2272kbps download which is actual up to 2.0Mbps only. And there is nothing I can do.
I managed before switching to ADSL2+ to achieve 2.5Mbps download being with ADSL1. Wish I had that now and wish it wasnt switched at all. Being with BT for 5 years I had this problem twice - 2272kbps download speed. I am not sure if plusnet techs can reset IP profile as BT engineers did before?
looks like will have to make a phone call again.
Re: G.dmt stuck
04-10-2016 10:42 AM - edited 04-10-2016 10:44 AM
Sorted
It seems a phone call is the way to make things better in 10 minutes
Still not the speeds what I used to have but big step has been done for the improvement
Kudos to PN techs
