Fully patched XP still finds updates for office 2007 (fresh install)
TORPC
Just installed Office 2007 for a client
Went via Start ====> Help & Support ====> Pick a Task ======> Keep your computer up-to-date with Windows Update ====> Custom Updates
Found & installing 6 updates
6 REPLIES 6
picbits
Re: Fully patched XP still finds updates for office 2007 (fresh install)
As long as Office 2007 is still supported you should get updates for that application.
It is the Windows XP and older versions of Internet Explorer (and XP based MSE) which are not supported any more.
TORPC
Cheer for that
I was posting my findings
In case the question may arise Wink
Since 1st post & after installing the  updates & restart
There another 43 updates
Will there be more after the next reboot (will await & see)
picbits
Yup - you have a few hours of updates still to go.
All the old ones are there, they just aren't releasing new ones. I've done a few XP installs recently lol.
PowerLee
Quote from: DomS
MSE will still get virus definition updates on an XP system till 14th July 2015, it will still also nag the hell out of you about the out of date operating system.
picbits
That's good to know - I'm sure I got a message that it was no longer supported. Will have to log back on and re-read it Wink
ReedRichards
Seasoned Pro
Fixes: 25
If you avoid updating MSE from version 4.4 to 4.5 you seem to get a working copy without the nagging.
