Fubared CPU?
- Fubared CPU?
- « Previous
- 1
- 2
- Next »
Re: Fubared CPU?
16-10-2008 5:58 PM
Whats wrong with Vista? It doesn't work on your PC.
Nuff said.
Re: Fubared CPU?
16-10-2008 6:52 PM
Quote from: God
It’s a bit of a pain as I want to sell the board and CPU but don’t really feel I can add the proviso, oh and you can’t run Vista on it.
That is why, also clearly there is an underlying problem. It appears ( following more research) that this BSD appears when there is an underlying stability problem in the system. I know it is the fashion to slag of Vista but one could argue that the fact it is doing extensive system checks is a good thing. The fact that XP 'nix and the others will run and then possibly fall over later isn't good.
Re: Fubared CPU?
16-10-2008 6:55 PM
This could cause the BSOD and it sounds like vista is more finickity about BIOS speeds.
Re: Fubared CPU?
16-10-2008 6:59 PM
Quote from: minkey Has the mobo been overclocked?
No. used but not abused, and bios reset and updated.
Re: Fubared CPU?
17-10-2008 7:50 PM
Did it get through the Vista install at all?
Did this occur when you went to activate?
Re: Fubared CPU?
17-10-2008 8:39 PM
Re: Fubared CPU?
18-10-2008 3:39 PM
Re: Fubared CPU?
18-10-2008 3:57 PM
Have you tried going into the bios and increasing the voltages on the memory and CPU a notch.
Alternately underclock the CPU and see if it makes any difference
Re: Fubared CPU?
18-10-2008 5:16 PM
Nope I have tried fail safe and standard settings only. If I get a chance during the week I will rig it up again and give it a try, any recommendations for the voltage increases?
Cheers
Re: Fubared CPU?
18-10-2008 5:40 PM
Seriously though there is a fair margin so a jump of 0.2 volts wouldn't hurt
- « Previous
- 1
- 2
- Next »
