Freeware PDF converter
Luzern
Fixes: 9
Can anyone recommend one that's easy to use and genuine free ware, rather than a come on with severe limitations to fet you to buy?
Use would be very light as would be used for attachments to forum posts mainly.
6 REPLIES 6
pierre_pierre
Re: Freeware PDF converter
Open Office - free and good comes with export to PDF pre installed - but bulky as a package but it isnt  Bill Gates and does read his files
two examples attached
pierre_pierre
another PDF of a BBC news item
Njal
Primo PDF
http://www.primopdf.com/
Regards,
Luzern
Fixes: 9
@ * NjalThat was one I looked at, but it came up with 5 items immediately and for some reason (?my stupidity?) I could not work out how to get the word item, I wanted converting, done.
[Moderator's note by Barry Zubel: Quotation of previous post removed as per the Forum Rules]
Daz1969
PDF Creator is pretty good:
http://www.pdfforge.org/products/pdfcreator
It's free, about 15MB to download and installs as a printer, so you can use it from any application that allows printing.
Darron
Borty46
CutePDF Writer is another possibility
http://www.cutepdf.com/
