Freenetname ftp not working
Roy99
Hi I have a website hosted through my old freenetname account which I have used for many years through the madasafish / plusnet takeovers
Has something changed within the ftp settings within the last few months?
I was able to upload fine in Nov/Dec 2018 but now with same details I am getting an error message
"cant get "http://www.users.freenetname.co.uk/" host entry"
ftp Settings have always previously been using WS FTP (and worked):
host name: http://www.users.freenetname.co.uk/
user id:  ******@freenetname.co.uk
Password: *********
regards, Roy
2 REPLIES 2
7up
Fixes: 20
Re: Freenetname ftp not working
You are using the FTP - File Transfer Protocol - to move files yet you are specifying a Hyper Text Transfer Protocol in the host address - http://
Remove the http:// and just use the actual domain name instead.
The http part is not valid in any ftp host name so I suspect WS FTP was removing the http bit invisibly and connecting to www.users.freenetname.co.uk directly without it. You said it yourself, WS FTP previously worked.
Roy99
Hi Thanks, yes I discovered this myself after playing with the settings some.
Like you say maybe something was suppressing it before, as it always used to work with the http in although I was not aware of that potential issue.
