Free webspace hosting
juliasdream
My son has registered a domain name and needs webspace, preferrably free
I have used up too much of my 250mb allowance on Plusnet so we neet to look elsewhere
I know some free webspace providers dont allow forwarding from a domain name provider so we need to find one that does
Can anyone advise
Fixes: 20
Re: Free webspace hosting
If you sign up to freeola. you get free webspace (similar to PlusNet set up).... Not sure of the exact conditions. ... but they also do a cheap webspace for about £3.50  http://freeola.com/web-hosting/
alternatively, what about a blogsite... like mine?  (hosted on google for freeeeeeee)  http://nemosphotography.blogspot.com/
matt_2k34
a freehost i had been using for some time was "Freehostia" (.com) its US based (pages can lag sometimes, but its never particularly bad) , and (back then) it offered alot for nothing, also the cheap packages are cheap anyway ($ to £ rates help Smiley )
Support was always pretty good too, <1 day turn around on tickets (had one in less than two hours), normally with a sensible answer
But i must stress this is about 12~18 months ago, havent used any webhosts recently....
(hey its free... worth a go?)
