Free video/audio player
samuria
Have a look at
http://www.kantaris.org/
Kantaris is an all new media player based on code from Videolan client (VLC) and Bass audio library. Kantaris has a graphical user interface similar to that of Windows Media Player.
Version 0.4.2 works with Windows 2000, XP and Vista.
Just tried it and its very good and well worth a look and best of all its FREE
11 REPLIES 11
shutter
Fixes: 65
Re: Free video/audio player
You will also need to download (or already have installed)  Microsoft .NET Framework 2.0  Wink
shutter
Fixes: 65
Have downloaded this and .NET framework and both went on seamlessly... so much so, I forgot I had started them... Have been listening and watching videos for past hour, and the sound quality through my external speakers is really good.
Think I will use it more than WMP for my video music.... Smiley
pierre_pierre
having trouble with one of my devices it doesnt like exporting Mpeg 4 to TV, just got this universal free converter, takes a bit of getting used to and had a small problem with lip sync  http://tinyurl.com/anyvidconv
shutter
Fixes: 65
Another one you could try Pierre                Quick Media Converter
http://www.cocoonsoftware.com/
shutter
Fixes: 65
The link you gave Pierre, gives a "evaluation" program    which means only 3 minutes of each video will be converted..... if a video is 4 mins 25 secs you loose the rest of it, unless you purchase the full version... Cry
My version "Quick Media Coverter" will convert .VLC files etc over 9 minutes IN FULL for FREE..... Cheesy
pierre_pierre
I only downloaded it two days ago and have converted a two hour program
pierre_pierre
just clicked the link and its definitely free and not evaluation Huh
pierre_pierre
it seems to me Gery you have got it the .wrong way round, your one - needs  activating - at a cost - mine just ran out of the box
shutter
Fixes: 65
Might need to "register" to activate it, (can`t remember)   Embarrassed     but that don`t cost anything.      Cheesy  ... mine didn`t.... ! Smiley
You know me, Pierre..... long time born Yorkshireman....  .. long pockets and short arms !!..  Cheesy  me? pay for software?  Roll_eyes  Nah!  it`s a myth  !!!  Grin
Njal
"How much?"
The cry of a Yorkshireman in pain.
Regards,
Neil
shutter
Fixes: 65
Too right bruv ! Cheesy
I was brought up on the Yorkshiremans prayer..... Every morning I had to read it..... it was on  my Grandad`s Tea Mug.... he sat opposite me at breakfast !!!. Roll_eyes
