Free use
minder20
Free use
Hi, I am a new plusnet user. Do plusnet have a limit to there free 12-8 usage?
11 REPLIES 11
pierre_pierre
Re: Free use
Welcome to the Forums
I have heard a figure of 50G fair use
Oldjim
Resting Legend
Fixes: 63
Re: Free use
No - there have been no reports of complaints
Fixes: 1,483
Re: Free use
Quote from: pierre_pierre
Where? I've blown that and not had anything said.
pierre_pierre
Re: Free use
well its not in the T&C, but As I Said, I have seen a mention somewhere, perhaps it was someone else thinking there was one
minder20
Re: Free use
Thanks for all your comments.... I have a sneaking suspicion that , like adiewoo i may be blowing past 50gb
zubel
Re: Free use
The 50Gb was a guideline for the Plus product, iirc.
I've certainly blown a LOT more than that in free time, when I was on Pro, and it was never mentioned.
B.
minder20
Re: Free use
Will the same apply to the value package?
Fixes: 1,483
Re: Free use
Yes minder no limit on the free period, knock yourself out Cheesy
pierre_pierre
Re: Free use
and just under this reply, bottom left corner is a link to check you usage, separated free and payed for by day and per month
doramason
Re: Free use
Quote from: Barry
B.
Is that 50gb per day or per month?
I've dl around 4gb tonite at free time, is it ok?
Fixes: 1,483
Re: Free use
That 50GB was for a product that is no longer sold, now there is no limit to what you may download in your free period. Smiley
