Free converter ram to wmv - (Now solved)
Midnight_Caller
Help and advice on getting a Free converter ram to wmv
I am not very good at searching for Software.
barky
Re: Free converter ram to wmv
the following should do it
http://www.formatoz.com/  Format Factory
select the all to WMV option
Midnight_Caller
Excellent it works strait off, thank you for your help.
