Free Ubuntu 12.04 CDs for Windows XP Users
- Free Ubuntu 12.04 CDs for Windows XP Users
14-09-2013 10:59 PM
Around 2,000 discs, to be given away between now and April 2014, have been produced.
The initiative is aimed at preventing electronic waste from discarded computers that, though unable to upgrade to a ‘supported’ version of Windows, would continue to function fine with an alternative OS.
And with some 20 million German PC users said to still use Windows XP the waste problem Munich hope to avert with this effort could be huge.
http://www.omgubuntu.co.uk/2013/09/ubuntu-12-04-lts-cds-munich-windows-xp
I have been upgrading friends and neighbours XP machines to Ubuntu for years, and without exception, they have ALL been VERY happy to be able to continue using their old machines, and been amazed at the benefits that Ubuntu has compared to XP, so much so that I get further upgrades to do now from their recommendations to their friends !
Now if only I could persuade 'Sprite'
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
Re: Free Ubuntu 12.04 CDs for Windows XP Users
15-09-2013 12:27 AM
15-09-2013 8:56 AM
I'd also question the choice of Ubuntu 12.04 (presumably, the standard Unity version) if this for old computers incapable of running Windows 7 or Windows 8. Xubuntu or Lubuntu would have been a better choice.
15-09-2013 9:55 AM
15-09-2013 1:17 PM
This could just result in Linux being associated with old and slow computers. I've got an old pentium4 system dating from 2002, it still works, even running Linux it's still pretty slow, I've largely stopped using it, at some point keeping ancient hardware plodding away ends up an inefficient use of electricity. If nothing else, the cpu just isn't fast enough to play 3Mbit 720p h264 video, and it's not as if a similarly old graphics card is going to be able to assist with that.
15-09-2013 5:18 PM
16-09-2013 11:25 AM
16-09-2013 12:04 PM
16-09-2013 12:32 PM
17-09-2013 12:20 PM
Must give it a go when my other problems are solved! I am not sure if the 1st HD in each machine can accommodate grub which probably needs an ext3 one and the others are all Windows, one certainly has all four primary partitions in use but it is not full.
If I go down the separate HD for Linux path, what is the drill to amend the BIOS to boot from it?
17-09-2013 2:09 PM
In the bios there is usually a boot from device section, then there maybe a bit to select which drive, depends on the age of the pc.
17-09-2013 4:03 PM
17-09-2013 6:19 PM
17-09-2013 8:18 PM
I have continued with that and although my main OS is PCLinux, I also have Mint and MEPIS installed just to try them out.
I always install Grub to the MBR on the internal (Windows) drive and have never had a problem. The new install invariably recognizes all the OS's I have installed.
Just a word of caution though. When installing Linux to a secondary HDD it will usually offer to install Grub to that drive. You need to make sure you change that to the Mbr on the main drive.
Another factor for me is that PCLinuxOS still uses legacy Grub rather than Grub 2 which creates it's own problem. But all the other main Linux Os's use Grub 2 and will install perfectly happily together.
17-09-2013 10:43 PM
Quote from: ejs Not all of grub is in the mbr. If the first part of grub is on the mbr of the first drive, but the rest of grub is in a filesystem the second drive, then you wouldn't be able to boot any OS without the second drive.
The MBR is just the first sector (512 bytes of the drive).
You could [carefully] take a backup of it with the dd command.
I believe Windows can wipe a Linux mbr and replace it with a windows mbr.
