Free ICS software?
Fixes: 10
Free ICS software?
Hi
Anyone know of any free internet connection sharing software?
Been trying to get a windows network bridge working in XP all day... it just says the network cable is unplugged all the time and i've wasted in excess of 8 hours.
Weirdly though i can still connect through that machine to the other one but the machine with th bridge cant see anything else.
I'd use nat32 but i am skint.
Thanks.
Fixes: 24
Re: Free ICS software?
Quote from: Sprite
Did you tell that machine what DNS servers to use when trying to access web sites?  The Plusnet ones are 212.159.6.9 and 212.159.6.10
Plusnet should give you a free wireless router, in which case you won't need to do internet connection sharing.
Many years ago I tried to get ICS to work between my new XP computer and my old one running Windows 98.  I spent a lot of time and failed.  I don't know whether it was a fundamental thing or just that at that time I didn't really understand the fundamentals of what I was trying to do; probably the latter.  Routers make it all a lot simpler.
Fixes: 10
I set the DNS servers to 192.168.0.1 - my ICS host which normally works a treat however the machine in question (ok wrong terminology using ICS on that) I was trying to get a windows bridge to bridge and lan and wifi card in AP mode so i could use it as an access point to the network.
I have a feeling zonealarm was to blame.. the latest version has some auto network detecting thing and I think it may of been blocking the virtual bridge miniport. I wiped the install again and reinstall winblows today and before putting any AV on or ZA I setup the wifi card and bridge. Bridge worked flawlessly (shame about the wifi card being a pain - RT2561 ralink based). The Ralink RT2500 chipset is a sinch to setup and use as an access point but they've become incredibly hard to come by.
Anyway I did find one bit of free software for bridging (and it was actually very good) called Ethernet Bridge. Instant bridging and you can set up a .bat file for Windows to run pre-logon so that it bridges the connections with no logon required. The only problem was that I couldn't control the internet connection through it like you can with a windows bridge and ICS.
Anyway wiped, started from fresh and now working (though i'm probably gonna take out the RT2561 card as its crap).
