Forgotten password in outlook express
juliasdream
I need to go into my webmail to fix some spam control but I forgot my password.
Its saved in outlook express so i can still send and receive ok
Does anyone know a way to find out my password from my outlook express?
I thought i rememberd but I've been through all I can think of and nothing works
Fixes: 384
Re: Forgotten password in outlook express
You could try a trial of the many paid for software that does a part reveal to jog your memory?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
maranello
Have you tried your PN Member Centre account password? By default, the Webmail password is set up as the same password.
My other car isn't a Ferrari
Njal
Lurker
Just ask PN.
They can access your password if you want them to, and its logged etc - but if you ask them, they should be fine about telling you (although I guess they might prefer a ticket too to give them total cover)
I'd raise a ticket, and post the number here, then at least they have a record of your request, and a secure way to give you the answer.
Smiley
James
Or in a slightly controversial manner, you could always call us Smiley
Lurker
I don't believe in telephonetics. Smiley
