Football streaming
- Football streaming
Football streaming
08-08-2009 3:56 PM
hi ive ust signed up 4 for the plusnet pro package, so i have max 15 gig of usage. Now the footy season is about to start i was wondering if anyone knows how much, streaming a full live football match will use on my usage? thanks
5 REPLIES 5
Re: Football streaming
08-08-2009 4:01 PM
depends the quality of the stream, do you know the bit rate of it?
08-08-2009 4:04 PM
i dont sorry, ive never had internet with a limit b4, the site r: iraq goals or fsi, if that helps a bit, lol
08-08-2009 4:07 PM
how would i find out the bit rate?
08-08-2009 4:16 PM
iraqgoals piggy back off other streams so your best way to find out the bit rate would be to use a monitoring tool such as NetLimiter2 (http://www.netlimiter.com/download.php ) which will show you how much traffic you are using.
You can then extrapolate this out to see for a full 90 minutes.
10-08-2009 9:59 AM
thanks, very much appreciated
