Flashplayer pushed out this morning not installing properly - 15th aug
- Flashplayer pushed out this morning not installing...
15-08-2014 1:20 PM
Mine never installed properly so it no longer worked 100% of the time with IPlayer/twitchtv, it would get stuck with the caching circle. Going back a version and then reinstalling the latest didn't fix it so had to do a clean install if anyone else has the same issue.
FTTP 500 regrade from Tues 28th November
5 REPLIES 5
Re: Flashplayer pushed out this morning not installing properly - 15th aug
15-08-2014 4:03 PM
Mine went O.K... all done and dusted in about 15 minutes... was doing breakfast at the time, so did not really bother about it....
What I can`t understand, is HOW? How do I get this message that an update is available, when I switch on my computer... BUT.. it is not yet connected to the internet... ? ? ?
15-08-2014 6:24 PM
It most likely called home prior to you shutting your computer down, & the activated itself for your perusal upon startup
What annoys me is that it never shows prior to either a reboot or startup
15-08-2014 7:49 PM
Yeah... it is always the first thing... first thing in the morning...like... Hey numbskull...update me first before you do anything else....
15-08-2014 8:40 PM
& then the splash-page stays above all others IIRC, or is that the Java one ?
15-08-2014 9:39 PM
I think that is the Java one.... same thing though... do me first or I wont let you use the computer ....
