Flashing Flourescent Light
- Re: Flashing Flourescent Light
02-03-2018 7:01 PM
Our kitchen is lit by a 6ft ( 1830 mm ) Flourescent Light fitting. it`s been ok for the past 7 years, at least,.. ( may have been working longer before we arrived ). Last night I switched it on as usual, but all it does is flash on and off repeatedly... I have tried to remove the starter unit, but cannot get a proper grip on it, to twist it,... Maybe use my "pipe grippers" when I can get to the shed ( snowed in !)..
Wondering if it may be the tube that has gone , or would it be the starter misfiring ?
Looking at the B&Q site they show several different wattage tubes,... but NONE of them have the lenght measurement under the descriptions ! ! !... Weird or what ?
Any suggestions which bit may be faulty ?
I could buy a replacement unit complete, but don`t really want the hassle of trying to fit it !
02-03-2018 7:18 PM - edited 02-03-2018 7:21 PM
Its usually the starter or the lamp, if you can get a cloth or something to help you get a bit more grip on the starter, turn it anti-clockwise and it should pull out, if the lamp comes on then it`s the starter. (that's if you remove it when the light is flashing)
02-03-2018 7:20 PM - edited 02-03-2018 7:22 PM
As it's located in the kitchen it seems you've managed to get flour in your fluorescent tube.
Forgot to mention, maybe the problem is temperature related due to the cold weather?
02-03-2018 7:27 PM
02-03-2018 7:27 PM
You'll notice that whilst some mention length, they all mention power which you'll be able to determine when you can remove the existing one.
02-03-2018 7:50 PM
@Browni B&Q is 1.9 miles from where I live... so I think Amazon in South Wales is a long way to go to take the old one for comparison ! ! !! ... ( thanks anyway )
@RobPN OK.... thanks for that information.... Pity that the company selling the items can`t put it on their site... from what is writ on the Wiki site, it seems I need a T8 6ft 70W tube... so... just to be on the safe side... tomorrow morning.. I`ll try to get th old tube out, and take it round the cornere to B&Q and let them sell me the right one ! ! .
cheers guys
02-03-2018 8:42 PM - edited 02-03-2018 8:44 PM
The old tubes don't seem to like cold and damp. The one in my shed often had flickering problems. I eventually gave up on that and replaced it with a couple of the small standard bayonet fluorescent bulbs.
I still have the one in my kitchen. Some winters it can be sometimes heard buzzing when switched off. Hasn't done it this year as I replaced the tube and starter in summer. Though that could be down to it being more cold and dry rather than cold and damp this winter here.
02-03-2018 9:25 PM
You may well find replacement tubes are much slimmer than old, but will still fit in the lampholder sockets.
This link may be of use:_
https://www.tlc-direct.co.uk/tcl/search?query=fluorescent+tubes&Submit=Search
02-03-2018 9:30 PM
I've replaced several of ours with an LED unit - brighter light and no flickering AND cheaper to run. E.G. LED-Direct-Replacement-Fluorescent
02-03-2018 9:52 PM
I have also swapped all mine for LED. You change both the starter and tube, you should find a 'starter' (for LED tubes it shorts the two pins) packaged with the tube. These are instant start and lower power with no loss of illumination.
02-03-2018 9:53 PM
Thanks for the input guys !.
@billnotben& @RobPN Cold and damp not in this kitchen... its at same temp as the rest of house... ( around 18c ) ...
@Gel Thanks for the linky... yes, I think I have seen the thinner onese, and used them before.
@MauriceC Interesting.. however, the price is twice as much as a "standard" T8 replacement... and the actual time on usage per day would be about 30 minutes so the "savings" on running costs would not be recouped before I die.... ! ( or moved house, whichever comes first ! ! ! ! )..
Point of interest.... Missus went into the kitchen just after my previous posting... and hey presto... it`s working normally again...
Amazing how you guys keep things within the PN logo/motto "We`ll do you proud" ! !
Thanks for all the input... case closed methinks ! ! !
02-03-2018 10:29 PM
6ft T8 replacement, decide colour, Warm White, White, Daylight...... decisions....
new tube could be thinner than present but will still fit fitting, Also suggest popping a replacement starter .
02-03-2018 11:32 PM
I fitted an LED tube in the kitchen, instant on, no flickering, no warming up, just light on demand, well worth the money given a lot of LED tubes now are at the same price as equivalent sized fluoro tubes...
03-03-2018 2:53 PM
Update !.... managed to remove the starter with a pair of pliers ! ! ... went to b&q ... got a pair.. (£3.00 ) .( you can`t buy one ! ! )... put one in..... no difference... so back to b&q new 6ft tube £12.00 a bit of faffing about, cos I couldn`t quite see the far end connector due to varifocal specs ! ! !.. to make sure the pins were lined up with the slot... but now all back together and working ...
cheers fellers !.
