Flash player in Firefox
jelv
Fixes: 10
Adobe have released a new version of Flash Player (11.3) that doesn't work in Firefox 13 (e.g. playing videos on the BBC new sites).
Disabling protected mode gets it working again: http://forums.adobe.com/thread/1018071?tstart=0
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
10 REPLIES 10
shutter
Fixes: 65
Re: Flash player in Firefox
I had problems after the new Flash Player download, vids on youtube, went green or blocky or did not play.... so I uninstalled Adobe Flash Player and the download manager .... then went to the site and downloaded a fresh copy.... installed it, and everything seems to be fine again....
Wink
Saved me a lot of messing around trying to follow the instructions in the linky........
ejs
Aspiring Hero
Fixes: 25
Adobe appear to have updated the linked article since yesterday, now blaming RealPlayer, any other extensions, or anything in your user profile.
Flash Player protected mode is only applicable to Vista / 7.
jelv
Fixes: 10
Firefox just popped the attached up
Fixes: 1,483
People still have real player? urgh.
zedingrove
Hi
Need to update your Java Platform, also Real Player is still out there but in a big way, ever hear of JW Player...
For you to watch a *.flv file you need to have the latest Java Platform and Flash plug-ins and there you have the problem, also will always check to see if you have the latest update for firefox.
Remember Firefox is like none other, also helps to be familiar with how firefox works.
Mav
Fixes: 515
Flash has been crashing regularly here for a few days. I uninstalled 11.3 and have re-installed 11.2.202.228 for 32bit and 11.2.202.235 for 64 bit and all has been stable since.
Probably don't need the 64 bit version as all my browsers are 32 bit ASAIK.
Forum Moderator and Customer
ejs
Aspiring Hero
Fixes: 25
Stable but with known security flaws. If you want an old version you're supposed to use a patched version of 10.3: 10.3.183.20
11.3.300.262 has been recently released.
Mav
Fixes: 515
10.3 doesn't work with some websites:(
I'll check out 11.3.300.262 shortly.
rongtw
Fixes: 12
I have FF13.01 with  version 11,2,202,235 installed and have had no problems
Steve
Seasoned Pro
6/21/2012 - Windows Flash Player Update
The Windows Flash Player plug-in for Firefox, Mozilla, Netscape, Opera and other browsers was updated to 11.3.300.262.
This release addresses stability issue found in Mozilla Firefox.  This build does not address the audio issues reported by some customers but we continue to focus on these problems and will continue to do so until they are resolved.
If you continue to have problems with this release, please see this tech note for suggestions and instructions for reporting these issues to us: Flash Player 11.3 compatibility issues with RealPlayer extension in Mozilla Firefox.
For full details on the 11.3 release, please see our release notes.
http://forums.adobe.com/message/4511145#4511145
If life gives you lemons, make lemonade.
