Not to mention java scripts and silverlight, All of which I use on a daily basis, Then I came across this Lovely add-on for Firefox so I decided to install It and help my antivirus along a bit, I like this better than NO-Script but remember this Is not a replacement for NO-Script, Yes theres much other ways to do the required job but this Is quick and easy for a novice like me
Quote |
Allows quick enable and disable of Java, Javascript, Flash, Silverlight and Images from the Statusbar and/or Toolbar without having to open any dialogs! |
https://addons.mozilla.org/en-US/firefox/addon/1237/
If life gives you lemons, make lemonade.
